giraffe said:
no shit.
is that a forced by product of the impedance matching?
or is it done separately and on purpose? (me knows jack about electronics)
what i'm thinking about is when you (and by you i mean me) put an amp in one room and use the 2 di box trick to get there, what are you loosing?
guess it can't be too bad, cause i've never noticed it, but hell........ 20db is a lot to lose on the way to a git amp, any where really.
this is all of course assuming that the second, run backwards, and un powered di box isn't somehow magically giving it back. which sounds stupid, but at this point i'm not going to take anything for granted because i apparently didn't notice i was loosing 20ish db of gain whenever i used a di box.
The loss is from how a transformer works. It's two coils of wire wrapped together. One is for the input, called the primary. One is for the output, called the secondary. They don't touch, the voltage gets passed from coil to coil by induction. The primary induces a voltage in the secondary. But they are physically separated. That's part of how DIs break ground loops. Using a DI with a ground lift means the two pieces are completely isolated, but signal still passes.
The turns ratio of the primary to the secondary determines the output voltage in relation to the input voltage. A 1:1 will get you the same voltage out as in. A 10:1 transformer gives about 1/10 the voltage out as in.
The turns ratio also determines the impedance that gear hooked to the DI sees.
A DI is an interface, kind of a window. When you plug a keyboard into a DI and then to a mic pre, the keyboard sees the mic pre impedance (say 1500ohms) multiplied by 10, or 15,000ohms, just about perfect for most line-level gear. The mic pre sees the keyboard's output impedance and signal level divided by ten, so it gets a nice low-level signal that has a much lower impedance. Typical line-level gear is about 1000ohms output impedance. Divide by 10, you get 100ohms, which goes perfect with a 1500ohm mic pre.
Sorry, I'm in kind of a rush. I don't know if you know the whole input/output impedance ratio thing, which says for best signal transfer, input impedance should be about 10X output impedance.
That's why passive DIs sometimes don't work well with passive instruments like electric guitar. DIs basically just multiply the impedance they are hooked to, they don't have any on their own. So most DIs have about 15-30,000ohms impedance, basically 10 times whatever mic pre they are hooked to, which isn't enough for passive pickups, which typically need 150,000ohms at least to work well.
