I'm using a computer like an external effects box via ADAT Optical cables between my Hardware recorder and an RME 5496 PCI card. The computer is also setup to send audio of VSTi's over the adat for recording. My comp is an AMD 64 2.2 or 2.3 Ghz single core, a few years old with 1Gb of ram.
Anyways, I'm having a problem with digital pops and clicks every now and then. Usually from making sudden changes to the audio processing, most notably, A/B'ing effects or bypassing them and turning them back on to compare what the track sounds like with and without. I've tried syncing the two pieces via Adat (each as master or slave), spidf, and now word clock. I will try Adat Sync soon too, but that hasn't resolved the issue yet. Also I've tried setting different buffer sizes and that only helps so much. I can get rid of some clicks that way, but most all the time I still get clicks with A/B'ing & bypassing and also when sweeping eq with a medium gain on it, though this is not as much an issue. Some more intensive Vsti's create pops/crackling too, but I'm thinking that could be a ram issue. The noise is not a continuous noise, it's more every now and then without reason but reoccurring enough to make it on the recording within a takes length, or by doing something specific that triggers it.
The end goal out of this all is to be able to route 24 tracks to and back from the computer in real time via Adat for signal processing, plus the vsti's. More less the audio seems fine when I'm not adjusting things. Like faders aren't a problem and most eq adjustments aren't either. The quicker I change something the more likely I am to get a click or series of light digital noise. So would this mainly be a CPU power issue? The trouble with that is, I could be running one track just the same as several tracks at once, and more likely than not still get clicks/pops doing the same types of things that trigger them. I also don't notice spikes in windows XP task manager when A/B'ing. I do notice sharp spikes when adjusting faders, and hear no audible reflection to that.
I'd like to upgrade my computer to a quad core system, it's just not in the cards yet. What can I do to get rid of the distortions or minimize them as much as possible for now? Do you think this is about CPU power or Sync, or Buffering, Ram etc or some other type of issue? Thank you much.
... Another question too about sync. What is the strongest most reliable sync method out of Adat, Spdif, Wordclock, & Adat Sync for a signal to go from a hardware recorder to a computer and back to the recorder? Which should be Master/Slave?
