nuemes
Be Here Now
I've got a Digi 002r system and am looking into adding additional inputs over the typical eight it supports. I understand that this might be done with the SPDIF, ADAT/Lightpipe, or firewire inputs on the Digi 002r but otherwise have hardly an idea of how this is done.
I've got a 20bit ADAT - but would it be able to be used with the lightpipe input given that PTLE records at 24bits?
If not, can you recommend an 8 channel unit that can do this (and maybe one with built-in preamps in addition if there's a pretty decent one out there)? Budget is $400-$700.
Also, how do they sync together?
Currently using preamps on a Soundcraft M8 & Avalon M5 if that helps.
