P
phlopip
or is it just me that finds it immensely hard?
Heck, I'm STILL struggling
Right now the settings I use for pitch shifter/detuner
-12 cents 14 ms delay 0% mix
+12 cents 19 ms delay 100% mix
you can also try -9 cents + 9 cents or maybe adust mix...find a setting you like.
Unless that plugin works very differently from all the others I know, those -12 cents and 14ms have absolutely no meaning because you are using 0% of the affected signal.Unless that plugin works very differently from all the others I know, those -12 cents and 14ms have absolutely no meaning because you are using 0% of the affected signal.
Some good advices there, like don't use presets, but I would like to emphasize that every mix needs different things. For example that "saturation plugin" might work in some song, but it is absolutely not a thing that you need in every song. Heck, I don't even know what it actually is! (Probably some kind of distortion/harmonizer plugin)
I know people (with less-than-stellar monitoring chains in poorly or untreated spaces) that have been at this for decades - and suck. Badly.
And I know people (who wisely invested in good monitoring chains and low end management) who started cranking out great sounding mixes in less than a year.
...and everything in between.
No doubt - Listening skills don't develop overnight. But they'll only develop as well as your monitoring chain will allow them to develop.
Where I started:
Where I am now:
Don't worry dude... Put your head down and you're cool![]()
You're never alone. Not here. Not when it comes to mixing !or is it just me that finds it immensely hard?
I think I'm a bit like this except that my mixes don't suck badly. They just suck !I know people (with less-than-stellar monitoring chains in poorly or untreated spaces) that have been at this for decades - and suck. Badly.
yeah, compression is one of the harder ones, I think. But just twiddling knobs was my best teacher. Crank em all up or down and see what they do to that track. Then back em off til it sounds right.
It's up and down for me. Truth is, I quite like my mixes and maybe it's because I hear others' that are so clear and uncluttered that I think mine are crummy, even though I like most of them.my second mix was pretty good...I thought id cracked it...how wrong i was![]()
This is such an encouragement. One doesn't always want to advocate this for fear of being publically slaughtered and I'd not advocate against things that others have found to be helpful/crucial. But there are more important things like the basics.One thing for the OP, in a recent mix contest amongst a few members here the winner mixed in an untreated room with a pair of behringer ms16 computer speakers and three effects, nothing else...it was a well tracked song but still it just shows...a decent pair of ears, a well tracked song, and some knowledge outweighs any room treatment or expensive monitors for most of us hobbiests
Funnilly enough, I've found this recently. Many times I've tried to mix at low levels and the urge to turn up everything is overwhelming !I don't have a treated room either, but I've learned to mix at lower volume levels for the most part and my mixes are getting much better.
But I've found with a little discipline it can be done and it's surprizing how clearly you can hear some things at low volume that are rather obscured when louder.
