I
inmyheartx
I was just curious if someone could suggest to me a good entry-level DI box for recording distortion guitars? Any help is greatly appreciated. =)
Take care,
Adam.
Take care,
Adam.
Word!!!!!!!!!!metalhead28 said:ha..simultaneous nearly identical responses are fun!
Farview said:just about any DI box will do it. Passive ones start out for around $30 list and go up from there.
BTW, Di boxes, in general, only match impedance, they don't change the level. They convert from high impedance unbalanced to low impeadance balanced.
That's a good point.irishfolker said:A Firepod has instrument and line level inputs, as well as the mic preamps. Why would you need a direct box?
I stand corrected. Well, really I'm sitting.Farview said:just about any DI box will do it. Passive ones start out for around $30 list and go up from there.
Farview said:It is a myth that direct boxes turn line level into mic level. It doesn't match levels at all.
Farview said:Nope. All of my cheap passive direct boxes are made with 1 to1 transformers. They have pad switches, but 0db of attenuation is an option. I have just measued the signal going through a DOD 265 and a Wirlwind Imp, what goes in comes out.
Farview said:It's been so long since I did anything with electronics, I didn't even have the meter set right.
