Drummer4Life05 said:
Awesome.
Thanks a lot Michael!!
Now, about these sine waves. Can you explain how they work, and how they tell me which frequencies are the problematic ones? And don't I need some sort of meter or something too?
Thanks again!
-Justin
OK, I'm sure someone will jump in here and correct me if I don't get this exactly right, but here goes:
A sine wave is a pure tone, kind of like a tuning fork, that is, its tone is absent any harmonics. This is valuable because you know exactly what frequency your hearing, or more accurately, what frequency you're generating.
If the room mode calculator depicts a problem at... let's just say 1000 Hz, then you can generate a 1000 Hz tone in your room. (I have a yamaha O1V mixer that will generate a few selected tones, but there are some tone generators available on-line.)
So you play that tone in the room. Then you move around in the room, listening critically, and if you hear a difference in the tone, (most likely this will be a sort of... wah wah wah as the frequency tone is being either cancelled out or added to by the wave bouncing off the wall or ceiling) then you know at that point in the room, at that frequency, you have a problem.
So then, you choose an appropriate acoustical treatment, that will tame that problem frequency, or more appropriately, RANGE of frequencies for that area.
Now, there are people here on this board that are a lot smarter than me on this topic. They can simply look at a drawing of your room, calculate the modes, and knowing the wave length of those problem frequencies, suggest a treatment.
For instance:
Let's use the 1000 Hz example.
We know thats a problem frequency for our hypothetical situation.
I
think the 1/2 wave length of that frequency is about 1.25'; it's 1/4 wave length would then be about 8".
8" from the wall is where the ideal place for a treatment to attenuate that frequency would be.
But 1000 Hz isn't going to be your ONLY problem frequency.
So they would design something that would attenuate a range of frequencies.
This is usually done by angleing a specific treatment across a wall or corner so that its depth from the wall varies; thereby varying the range of frequencies that it will attenuate.
