bouldersoundguy
hi jimmy. the 2nd paragraph of the sos article:
If you want to place something at the back of the mix, it not only needs to be quieter than the up‑front sounds: it also needs to have less top end, to emulate the way air absorbs high frequencies.
they should a graph on the right of their eq and it has the top and low end cut off.
You lose HF to some degree at distances on the order of hundreds of feet, and even then it's more subtle than that eq shown. It's totally irrelevant to depth in the sense of front of the band versus back of the band. For distance of that type it's going to come from how you record and how you set your reverbs and delays, especially early reflections. There's a third version of distance, mic proximity effect. Things recorded close to a mic tend to cause proximity effect, a boosting of the lows and low-mids. If you do a cut in that range it can suggest that the source is not so close to a mic.
