Delta 44 Question
  • Thread starter Thread starter AlexHerd
A
AlexHerd
Got a Delta 44 for Christmas, and I have some questions: Is there anyway that I can have all the sound go to one output? I don't have monitors yet so I have to use computer speakers, and also I want to plug headphones in. Also, Can I hook up the computer CD player to the Delta, or would I have to plug in my old soundcard for that? THANKS!
No they are mono outputs. If you did it would be mono signal. You need to have a left and right for a stereo output to use 2. Im sure they have some sort of a cable that will do what you want. it will probably take a lot of adapters and connections though
Within your software mixer, you can output all tracks to chl.1 and 2. This will allow you to use the 1 and 2 output ports to hook up any type of speakers using a 1/4 adapter. I dont believe there is a headphone jack on the 66. You would need the omni studio.
As far as your CD player, there is no physical connection made to the 66 like it is with your current system soundcard. If your using WIN XP you can set it up to play audio from your CD drive, otherwise you will need to keep your existing soundcard in.
