K
kirkhere
I'm looking into one of these two cards for a series of project studio recordings that friend is writing. He put some "demos" together and has asked me to pick up the project.
He was working with a Mackie VLZ1202 Pro and the older Gina 20, but driver support for Win2K and later Win XP is beta only, and will not be further developed from Echo. I haven't been thrilled with it. I'm looking for something to replace it with since I'm running XP only.
My inclination was to stick with Echo and go to the Gina24... but several aspects of the Delta 44 cards appeal to me more.
In Delta's favor, I count:
--mic pre-amps supporting +4 and -10, bal and unbal input (which I don't need at this time, but which would be useful without bringing the Makcie along);
--broader driver support; switchable input levels
--more flexible software routing/mixing
--about $100 less
In Gina24's favor I count:
--higher dynamic range peak (according to the specs)
--built-in headphone monitor with vol control on the breakout box
Just plain differences which don't I don't believe affect this decision since I don't currently multitrack or use SPDIF:
--Delta 44 has 4 in and 4 out
--Gina 24 has 2 in and 8 out
--Gina has SPDIF
Final thoughts... I was considering the Delta Omni Studio (the Detla 66 plus the Omni I/O), but I believe that it's overkill, considering I have the Mackie. Plus its cost is about the same as the Gina24! If I ultimately determine that I need to spend that much, then I'd probably go with the OmniStudio for the added value that the extra hardware offers (even if I may not need it immediately).
I'd appreciate it if anyone had any opinions about this setup, or other gear that you'd point me toward. I'm always interested in learning more, particularly if my own decisions may not be the best!
Thanks,
kirkhere
--about $100 less
--Gina has SPDIF
Thanks,
kirkhere
