K
Kaz
Heres the story
I got my Delta44 (right from GuitarCenter), took it home - read the instructions. I opened my comp. and put the Delta in an empty PCI slot (keeping my Creative SoundBlaster AudioPCI), turned the computer on - recorded a little something in Cool Edit, and it worked like a charm! So I turned the computer off for the night.
In the morning I booted the computer, went to Cool Edit, and hit 'Record' - The computer turned off, and restarted. I tried again, and the same thing happened. I then tried with N-Tracks, and once again the computer restarted - so I'm thinking "It must be the Delta and the SoundBlaster conflicting", I turned the computer off, took out the SoundBlaster card, booted the computer and all I got was the startup noise skipping for like 10seconds then the computer restarted itself, and it went into a cycle.
So I turned it off, took out the 44, put in the SB, turned the computer on - everything was fine. Turned the computer off, put the 44 in, turned the computer on - everything was fine, recorded in CEP, worked fine. Restarted the computer, went to CEP, hit 'record', computer restarted.
Then I took out the Delta44, booted, removed the SB from the "System Properties >> Device Manager", then turned it off again, took out the SB, and replaced it with the 44, worked good - restarted the computer, and it just did the skipping on the startup sound, and shut off again.
Right now I don't have a Soundcard in my computer, and I need some REAL help with getting the Delta 44 to work - if ANYONE could help me with this I'd be in much debt to you! I'm a graphics designer / webmaster, maybe that can be an insentive
Thanks in advance,
- Kaz
Thanks in advance,
- Kaz
