T
ticker
Hi all, I ran a few searches in an attempt to avoid what has probably already been posted. Maybe I have given up to quickly, but I am going to go ahead and ask anyway.
I have a Sennheiser e609, a Delta 1010LT, a Fender Blues Jr., and several effects. The amp dialed in at volume 3 is plenty loud for me and the tone is just right for my little home recording tastes. I'm using an XLR jack on the Delta card and first tried setting the input slider just in the middle. Recorded a few minutes of jam and played it back in my recording software. The levels were not right and I heard the horrible static and such on playback. So I decided to try it with the input level all the way down. A little better, but still facing the same problems. I have the mic literally hanging off the amp so that the it is resting on the protective cover. I did try moving it out several inches but it only killed the tone and produced a weaker signal which still made lots of unwanted 'you have too much signal' noise. I have various other equips going through the card. Drum machine, moog, nord, etc. I've got them all working just fine.
I did find some posts about changing jumper settings but unfortunately I do not understand how that affects the signal or whether or not it will help. If anyone can offer advice I would greatly appreciate it!
