Superhuman
Shagaholic
I set up two separate output BUS's in SX3 - through a Delta 1010.
Bus 1 - Delta 1/2 out = "Monitors"
Bus 2 - Delta 3/4 out = "HUI headphones"
"Monitors" is self explanatory but I set up "HUI headphones" to be routed to the HUI and out from the outputs on the unit for when I want to use headphones during mixing or recording.
The problem is when I select "HUI headphones" as an output BUS in a project it still goes through the monitors and not the headphones... I can't figure out why. According to the VST Connections window the HUI is setup to Delta3/4 but when I choose this in the project it still plays through Delta 1/2.... what gives?
