Delay effects for mono vocal?
unnidotcom
Hi..
Is it possible to give multitap delay effects to mono vocal in Audition 1.5?
Can you suggest the ways to apply delay effects such as Left to right,Right to left ,Centre to surround etc to mono vocals ?
Thanks and Regards,
Unni
It is possible but I don't remember exactly what delay effects are available in version 1,5.
Add BUS track to your multitrack view first.
Anyway do insert some compressor on mono vocal track.
Insert your multitap delay on BUS track and then send your vocal track to BUS.
Trick like Left to right etc should be tweaked on your Delay effect. There should be some presets as well. Your vocal will still stay in centre but BUS will send effect reflections etc to both sides depending of your tweaking. You can do it without using a BUS track of course but this is how I use time based effects.
Consider to add studio reverb as well on BUS track. Put it at the end of the effect chain.
