Confusitron
Our band has accumulated enough money to invest in a PA system. We are looking to buy a mixer, PA speakers (and power amps), and whatever else is needed. I have some questions in regards to what equipment we should be looking to purchase.
Our band includes (these instruments will all most likely be connected to the PA simultaneously) (two) guitars, (two) keyboards, bass, drum set (five-piece at the moment), auxillary percussion (possibly), and (about five) vocals.
With that many instuments attached the PA simultaneously (if guitar amps are DI'ed and miced, which seems logical to me), it appears we would need at least a twenty-four channel mixer, however, that would leave us with very little slack since we would be using almost every channel. So, probably a twenty-eight or thirty-two channel mixer would be more appropriate. What mixer/brand(s) of mixers do you suggest?
For speakers, I was thinking that two 15" cabs (woofer and horn) at somewhere around 350W would be appropriate. If it is necessary, then I would think that buying two 18" cabs (only woofer) at the same wattage or more would be a proper addition. I am unsure of stage monitors as of right now. What speakers/brand(s) of speakers do you suggest?
I am unsure of power amps. I would think that maybe I should be looking at QSC or Crown power amps for the speakers, but, that and the wattage is really all I know about. What power amp(s)/brand(s) of of power amps do you suggest?
I have many other questions which I may be asking later.
Thank you for any assistance.
