cordura21
I am going to rebuild a noisy strat circuit. I don't know what makes the noisy.
My theory is that if I go from the simplest circuit, and then begin adding components, at sometime I'll find the offending little bastard.
So I'm gonna start attaching one pickup to my amp cable, the red lead to the tip, and the white one to the sleeve.
My questions are:
1- should that work without noise, or doing this simple connection will bring noise too?
2- Shouldn't it make ground thru the sleeve, or should I put another ground (like the manufacturers, who use the bridge as ground)?
3- Can I make it and test it outside the guitar, or doing this brings more noise (being that it's not under the plastic case or the metal plate)?
Cheers, Andrés
My questions are:
Cheers, Andrés
