andrushkiwt
I was working with a particular vocal track over the weekend that had quite a bit of sibilance, and it was made worse with the amp sim the vocals were run through. The vocal chain was: 1. EQ 2. Amp 3. De-ess and that track was sent to a buss with some further processing. The de-esser on the vocal track seemed to not be doing anything. I also say this because lowering the threshold to the minimum showed 0 gain reduction. I was using the same settings I always have: 20:1, fast attack, slow release, filter 5khz-max, and then various thresholds to see if anything happened. Yes, the plug-in is "on". Vocal buss chain is: 1. EQ 2. de-ess 3. comp 4. delay - w/ sidechains of reverb and the guitar compressor.
You can see I have two de-essers affecting the vocal track, one on the track itself, one on the buss. Which compressor "works" first as the signal passes through? the individual track, correct? If so, why is the de-esser on the buss working (well, somewhat, or else I wouldn't need to use another one) and the track plug-in isn't? Someone will probably think, "if you need to use 2 de-essers, fix the original problem", and I understand...but can we assume I cannot and that I can only work with this for the time being?
FYI- I see the gain rising and lowering with the vocals on the de-ess plug-in; it even rises above the threshold i set, but it shows no reduction, just simply flies over that point without being touched.
