T
tollbooth
hey guys
i have a track recorded by someone else that has a fairly poorly recorded djembe on it (big whumpy drum for those unaware) - the drum has a lot of bas end decay but little top end crack to it.
as it's fairly exposed in the track (it backs a medieval vocal ensemble) i can't 'resample' it too easily with another sound (which i was tempted to do)
it needs a little reverb to help it sit with the rest of the track, but on doing so (i'm using TrueVerb) i just get a wash of BOING!!! i've put a hipass filter on the reverb and that helped a bit
in the end - i ran a compressed and gated drum track out of Digital Performer and out into a hardware SPL Vitalizer Jack and then back in on another track - this is normally designed for ADDING psychoacoustic bass into tracks, but you can also tighten the bass quite a bit with it too. this seemed to o a passable job. i needed to keep a lot of bass in the drum track as it is the only thing adding any low end (all the vocals are alto and soprano!).
the resulting track sounded ok, but i was just wondering if anyone would have gone about it a different way?
i suspect i may have more from this client in the future of a similar vein so i would be interested in any other ideas.
thanks guys
paul d
thanks guys
paul d
