N
Newbie dude
What is DC[ Direct current I'm assuming?]offset?
SouthSIDE Glen said:These bias currents are usually - but not always - introduced by cheaper computer sound cards. They visuallly manifest themselves in audio editing software by a base line in the wavefor display that rides above or below (depending of positive or negative voltage) the "center line" of the display. For instance a small bias current can result in the editor recording a flat line at -15dB instead of the "-infinity" centerline. This "offset" cuts down on the usable headroom available for the wavefrom.
A "DC Offset" rectifier circuit (or software plug-in) acts to remove this flat line "offset" and return the flatline to center.
G.
biggestmuff said:Okay, but how does this affect what I hear? Why is DC offset a bad thing? How does it hurt a recording? Is there anything positive about a DC offset?
Glen said:This "offset" cuts down on the usable headroom available for the waveform.
There is nothing positive about it whatsoever. It is inadvertantly added "noise" that is not part of the original signal, and therefore completly undesired.biggestmuff said:Okay, but how does this affect what I hear? Why is DC offset a bad thing? How does it hurt a recording? Is there anything positive about a DC offset?
Hopefully the designer of the power amp had the sense to block DC at the input
Just educated guess/speculation here, but I wonder if what you're getting is true DC bias or just extreme LF coloration that may be building up across tracks and causing what appears to be an "offset", but is really a floor of subsonic mud.noisewreck said:Having a high-pass filter set around 10-15Hz will effectively eliminate the DC offset.
One thing I don't understand is how sometimes I end up getting DC offset on mixdowns or submixes. I always take care so that my individual tracks don't have DC offset, however, after mixing, at times DC offset gets introduced. Is it possible that compressors and other FX might be responsible for this? Please note that I mix in the box using Cubase SX 2. The EQs and compressors of choice are the UAD plugs.
SouthSIDE Glen said:DC (yes, this does mean direct current) offset is when there is a DC "bias" current introduced in the signal somewhere along the chain. This current can be positive or negative, but it is a low-voltage DC current nonetheless.
G.
Thanks a bunch Benny. I wish my recordings were as clear as my writings, sometimesbennychico11 said:here's some pretend rep points for you Glen
I tried to give you some but it says I need to spread it around before I give you anymore (even though I think it's been awhile since I've rep-ed ya)
props for this explanation. crystal clear as usual.![]()
noisewreck said:. Could a massive subbass (think Drum and Bass tune) that centers around 40-60Hz cause that?
I have to say that I have seen several laptops - and one or two PCs with mobo-based sound cards - that do indeed introduce this much offset. In fact the integrated soundcard on my current Toshiba laptop does this. I don't recall just how much it measures out to, but it is quite signifigant (at least -25 to -30dBFS positive, if not higher).bleyrad said:It uses some simple math to (essentially) find the average zeroing value of the waveform. The thing is, only pure waves are always totally symetrical. This means that normal music will almost always show some DC offset when analysed in this matter, even when there is none at all.
In other words, unless the offset is significant and/or you know you have a DC problem in your gear, you are usually better to do nothing about it as you will likely actually INTRODUCE a real DC offset if you go about "fixing" it.
Also keep in mind that practically all modern recording interfaces/soundcards will totally block any incoming DC before A/D conversion. Even cheap ones.
A DC offset which limits your dynamic range to 25db (as in an example someone else mentioned) would be a sign that God Is Angry At You. Seriously, you would probably have to intentionally bypass the DC protection circuity and jumper-cable a car battery to your soundcard input in order for something that drastic to happen.
. But in playing around with it and the DC Offset plug in Adobe Audition, I find that if I record some silence at the beginning, letting the offset plug work on the flatline. it brings it to zero fine, of course. When the music begins there is no noticable or appreciable variance in the offset with the live data. Of course, as you say, since the plug is "synthesizing" (i.e. guessing at) the zero point, some error has to be expected, but it's probably quite minimal.Yeah, both you and blyrad have mentioned this, and they will for a pure DC signal. You guys are right that my example would not really happen in the real world with a decent amp. It was more for illustration than anything.mshilarious said:Hopefully the designer of the power amp had the sense to block DC at the input
