Massive Master
www.massivemastering.com
Have you read anything on this thread...?
Farview said:The 'bar going up and down is a peak meter, not a VU meter. -18 on that meter is line level. Your signal should average -18, not peak at -18. If you are clipping, you are recording too loud. If the mix is too quiet, then you need to compress or limit it to get the volume up. The recording level and the mix volume are two separate things that are not necessarily related.
Those podcasts were probably compressed then normalized to get the peak level at -2.
dbVU is only in the analog world, dbfs is only in the digital world. You should never go into the red. Your peaks can be at -3, as long as it is only occasionally (or you are recording percussion)VictorGalaxy said:Okay, if we average at -18dB at that adobe audition bar, then we can peak at around -3dB right? So it never go too red red....Oh that means adobe audition's bar is showing dBFS and not dBVU??
You have your choice of either pristene dynamics and a quiet recording, or a compressed loud one. You should not be getting distortion from your compressor. You may have the attack and release times set wrong.VictorGalaxy said:But sometime when we use compression(with output gain more than 0) then yeah, our track's volume will be higher, but I always feel that the compression process may distort my sound track more or less....
It would depend on the calibration of the unit. A self contained unit is the same thing as having outboard preamps, an interface, and a recorder. They just put all that stuff in the same box. The same rules apply.lacmackenzie said:so...does -18dbfs average level apply only when going from analog outboard gear into a DAW?
On a self-contained multitrack recording unit does the same rule apply?
No. The problem with running the levels that hot on something without any dynamic range, like distorted guitars, is that you are running the preamps and everything in the analog chain 15db above where it was designed to work.If I know a recording won't clip, for instance heavily distorted guitars, I suppose there's no need for 18dBFS headroom and I can just as well set the recording level to peak at -3dB in AA. Is my assumption right?
