P
pointfive
This is potentially a dumb question, and I think I know the answer, but I know most people here know it for sure, so...
I have a Yamaha Subkick. This mic puts out a very hot signal--it sometimes distorts even with the gain on my mic pre all the way down. This is mentioned in the documentation that came with the mic. That documentation goes on to mention that a -20 db pad may be needed in such cases.
My question is this: I have a DI box (http://www.zzounds.com/a--2676837/item--BEHDI100) which has 2 attenuation switches (-20 db each, if I'm not mistaken). Could I run the Subkick through this, using the attenuator(s) to lower the signal? (My instincts tell me this probably won't work--the DI box will boost the mic signal even more before attenuating it, right? This is where I'm unsure.)
Or do I need to get something like this: http://www.bhphotovideo.com/bnh/con...s&Q=&sku=351406&is=REG&addedTroughType=search ?
I've been meaning to experiment with the Subkick through the DI box, but haven't had the time yet.
