L
Lavely
I'm going to build a DAW to do some simple (!) recording of solo guitar, either through an interface or using a mic on an amp, I want to create virtual drum tracks using software, I may lay a vocal track, may use a keyboard eventually.
I am going to build the DAW - does a new build need any special cooling? Looks like most CPUs come with some sort of heatsink or fan that goes on top of them. Also, the power supply will have a fan on it already, right? Anything else I should do to keep it cool, or will it be fine on its own? I'm looking at a Q6600 quad core and a ASUS P5N-D motherboard.
Any suggestions for dropping the quad core down to a dual core, and a motherboard that will go along with that switch? I don't really need quad core power...
I am wondering can I scrounge a power supply and the case from an old Dell? Or, does this create issues with a new build fitting in there? Never built a PC before...though, I have tinkered & added parts in the past.
If I install Windows XP, is Pro or the Home edition preferred for ease of use?
For a videocard, sounds like a low-end $25 card like the EVGA 7200 GS will do just fine. Any other opinions on this?
I am using a Line 6 UX2 to get my guitar signal into the PC. Do I need a soundcard at all if this is my interface (via USB 2.0)? Can't I simply plug my speakers into the UX2 and avoid a soundcard altogether?
With the Line 6 UX2, I'm hoping to use Reaper recording SW and Addictive Drums. Anyone have issues with compatibility of these three pieces of HW/SW?
Thanks in advance!!
Lavely
Thanks in advance!!
Lavely
