Daw control for Pro Tools and Pro Logic X
  • Thread starter Thread starter BurnyMA
B
BurnyMA
I was wondering if anyone could give me some advice regarding a mid sized high-end DAW Controller with approx. 24-36 faders. I am a composer and songwriter and intend to invest quite a large sum of money in my own semi- professional home studio with a control room and a live room for recording vocals only. At present, I am running music production under Pro Logic X and recording through Pro Tools using a SSL Nucleus, which unfortunately cannot do any summing. However, most of the large high quality consoles (i.e. Avid S6, Yamaha Nuage) are mainly adapted for post-production and not an issue for music production. I have also looked at the SSL AWS 924 and 928, which bring back memories recording back in the 80s. So maybe there are a few good recording engineers out there, who could advise me on this issue?
Hi. Steenamaroo.
I am looking for a control surface. As mentioned I am using a SSL Nucleus at the moment, but want more control when using up to 60 Channels for orchestral works.
really?!?!?! the nucleus is not enough! thats is a great/awesome/expensive equipment, not enough inputs for you?
The OP is looking for greater control, which I guess means more faders.
Sorry Burny. I don't know anything about the larger control surfaces.
:confused: Control surfaces don't "sum". Explain what you want here.
I think it's safe to say we don't understand what you want... The Nucleus is a fine board and can handle several banks of tracks. The AWS-series is a completely different animal, designed for tracking lots of inputs at once. As you describe, you're tracking vocals-only, which should be easy via the Nucleus' mic pre's. If you want something with more faders than the Nucleus, then there is the Avid C24 or System 5-MC, but it's not going to change the sound... just give you more worksurface.
Go get Waves' summing plugin and be done. There's no point in investing in a true summing mixer unless you have the massive I/O to run the audio into it.
