Peter Ochello
Hi gang, I've been off of the BBS for a while concentrating on a recording project.
I'm not a newbie by any means but I need to know if anyone has tried this configuration
or experienced this problem.
I'm trying to use two sound cards, one for mains and one for a headphone monitoring mix.
I have a SB Live handling my main stuff and a cheap little SB16 running the monitor mix.
For the monitor mix I take the signal from the Aux sends. This works really well, by the way.
The problem I'm having is that as soon as I arm a track for recording it kills the Aux send.
So, if I have my music recorded and I'm laying vocals on a track I can hear the music in the
headphones just fine. However, I can't hear the vocals at all. It's as if arming the track for
recording defeats the Aux send for that channel. That's no good, if so, since CW recommends
using the Aux's for monitoring purposes. CW also does not recommend using two
soundcards yet the software has allowances for it. Pretty strange. Incidentally, I have
simultaneous record/playback enabled. The SB16 is not used for recording, only
playback. So, it shouldn't matter if it is full duplex or not. Any suggestions......thx....pete o
