R
Room 9
Was curious on your thoughts of cubase vs protools for virtual instuments. Does either have an advantage here in terms of range of instrument choice/ ease of use? Thanks
Just isn't true at all and:I can tell you right off the bat that Pro Tools comes with zero "instruments" and close to no plug-in options. I comes with the standard "basic tools" like compressors, gates, expanders, reverbs and Dither. Pro Tools is easier to learn and use, and it is standardized in the audio industry....but thats about where the buck stops.
also not true. Case and point. Go to the vendor's website and decide for your self. It is all about what you want to do and how you want to do it.Pro tools it was originally for audio only and to my knowledge sucks at MIDI. I am biased though because I love Cubase for anything its great!
You should check the official websites for Avid/Digi and Cubase. Don't go by someone else's preference. Reason being that you will get the bias from others. For example:
However, any of the DAWs mentioned can support third party Virtual Instruments, relatively easily,
Well I'm just saying it how it is. A basic Pro Tools LE package comes stocked with what...
The bombfactory Bundle and the standard Digi RTAs stuff. Unless that's changed from now to a year ago, there's really no bias.
But it's true that opinions shouldn't be the point of buying it. I'm certainly guilty of ignoring opinions in favor of research all the time.
Pro Tools will be RTAs based (unique only to them, which can be a problem)
If you're on the Mac, then Logic is king in this regard.
