Here I'll try again..
I just typed a huge explaination that was excellent...and I sent it...and lost it?????? I'm pissed. hahaha In short this time:::
I mixed my song. I have never done any 'automating' yet. I have one part that I want noisey. I saved my noisey mixer settings....as well as my clean.
I wanted to mix down just the noisey part, so I selected using the pencil thing, the part. I loaded the noisey mixer settings. Went file, export, audio mix down (where I did select with automation and stereo interleaved or whatever).
Then I wanted to mix down the whole song, without the noisey part. So I selected the longest track and hit 'P'....Then I loaded my clean mixer settings and again, went file, export, etc.
Note: on my master effects, I am running Ozone to master it abit.
For some reason the mixed down audio for the 'whole song' had the noisey part noisey (I checked the mixer settings during this part and they are set to my clean settings...so it's not like it is automating), and it sounds like it mastered it twice or something......because when I boosted the highs and lows, the mixed down version sounds like the lows are super woofy, and the highs are super shrill.
Also, now when I open up my session, I try to change my mixer settings, and I can't do anything. It's like I'm just listening to the mixed down version (with it mastered twice...the crappy sound). I can't change anything except I can turn off my master effects and I can adjust them as well. I pissed around with the mute/solo stuff, and I found that if I solo a track, and I put the fader all the way up, then all the way down, it's like it unlocks or something and then I can change the settings on that track.
I thought I could just mix the song, mix it down, burn it, listen, make adjustments, mix it down, etc.
Note: I have read the manual extensively with no luck. I'm resorting to you guys. I hope I've clearified stuff. Thanks. Greg.
