Cubase sound randomly quits
  • Thread starter Thread starter sean.hanlon
sean.hanlon
the cpu doesn't freeze and if I quit and re-open the song, it plays fine (temporarily).
Sometimes the sound stops and comes back, sometimes it just quits entirely. I have a g-4, 350 mhz, 128 mb ram...seasound solo ex soundcard.
Anyone run into a similar problem?
I have a similar problem but it's only on the demo version that I was given in the store.
I thought that perhaps as I have a 5400 IDE drive the problem will go away once I upgrade to a 7200 drive.
BTW, it sure sounds good!
foo
Have you checked under tools>system within Cubase. What in your soundcard driver listed there, Does the seasound support ASIO? Is it select as directX?
Also, Under Start>Programs>Steinberg. There should be some configuration programs there as well, setupmme etc. Play around with those and see if it helps.
man, I just realized your running it on a Mac, - names should be the same, just a different route.
