J
		John Delves
I have a problem with recording on cubase that maybe one of you has seen before. I want to use my rig to multitrack record mostly guitars bass etc and have a problem with the tracks staying in time. I record one track to the click and it sounds fine. I then record a second track. Then when I play them back together they start out in sync but slowly they end up totally out of time and sounding horrible. I've tried to change the sync settings tried detect buffers. I've changed channel memory size and sample input/output options. I tried to change vcache and virtual memory and all the other options I can think of but all that did was make me fail the sync test. I tried to change buffer sizes but couldn't find a happy number and changing to 48000 from 44100 for sampling rate didn't work. My setup is a P3 500 running win98se w/ 128m RAM. My soundcard is a Soundblaster Live! which I know isn't the best but I see other people using it and it works. Kinda loosing faith and I'd sure like to get back to making music instead of screwing with my computer all the time. Any help would be MOST appreciated. Thanks.
