Cubase LE 5 & Audacity Effects?
  • Thread starter Thread starter Blackthoven
B
Blackthoven
Hello all,
I'm curious to know whether or not I can somehow use effects from Audacity (e.g. Bass Boost, Paulstretch, Noise Removal, etc...) in Cubase LE 5.
I could just export an audio track from Cubase, load it onto Audacity, use the effect, and then export that once again to finally re-load it on Cubase. But that will be a huge hassle; it would be much more simple if I were able to just some how add Audacity's effects to Cubase!
If anyone has the answer I will be eternally grateful.
The effects that come with Audacity are hard-coded into the program; you can't use them with any other audio program.
Exporting a track into audacity and then bringing it back in (as a COPY! Don't overwrite your originals,
just mute them in case you have to adjust them again) is the way to go.
