xstatic said:Do I care for the Cubase channel EQ? No. Is it worthless? No. If you can not hear the Cubase EQ until 10 or 12 db of gain than....
1. You can not hear well and probably look for a new hobby...
or
2. Your system is not capable of adequate or decent playback, llok for some new monitors and/or converters.
or
You have to push the button to turn on each band of controls. If it is on, there is something wrong with your monitors or your ears.pinhedgtr said:Is this thing totally worthless or What? It seems like I can't even hear a difference untill I raise the EQ gain to like 10-12...does'nt matter what frequency. Does anybody else have this problem or do you all use plugins for EQ?
If you are using small monitors then the lo end prob wont be as loud, so you will add more lo end at mixing which in turn ends up being too much.xstatic said:That is something that room treatments will certainly help, but better monitors will also help this quite a bit. The problem usually lies in a combination of room treatment, learning your monitors, experience, and needing better monitors.
