Hello,
I am trying to export the audio files for a vocal and backtrack as per instructions from a someone who will be doing the mix.
They indicated that the first project should have 5 audio files and the second one should contain 7. When I do the export, there is only one audio file per project. I will post his instructions below. One point where I had issues was in the Audio Mixdown window. The instructions mentioned clicking on the Channel Batch Export, I do not have that option on my version of Cubase. Not sure if this would have any bearing on the export generating only one audio file.
I have also attached a screen shot of my Export Audio Mixdown window and a screen of the project.
Insructions:
1. Set the Locators, they are in the timeline in cubase. If you drag one to the right it should show a blue highlighted area. Make sure it's blue and NOT red. (You could also select the longest file and press "P" on your keyboard, that should do it too).
2. Make sure non of the tracks are muted.
3. Go to File > Export > Audio Mixdown. A window will pop up. On the left side there should be "Channel Batch Export", click on that so you'd see the check mark.
4. Check all the audio files in the list. Make sure you see check marks in the little boxes next to all the audio names.
5. Choose a location to save the files. It's under "Path" on the right side, there's a small arrow that if you click on it, it should let you choose where you want to save the files.
6. Under "File Format" choose "Wave"
7. Under "Audio Engine Output", leave the "Sample Rate" and "Bit Rate" the way they are (should be either 44.1 and 16, OR 48 and 24) and make sure the 4 options next to it are NOT checked.
8. Click "Export".
Insructions:
8. Click "Export".
