So I have been doing this for a while and just wondering if there is a better approach.
Current Workflow
Create New Project1
Record Scratch Track of entire band. Just a couple of room mic's and (Midi Input from eDrum Kit to trigger Superior Drummer)
Export Stereo Track of Drums to new Audio File (Generic Preset from SD at this point)
Create New Project2
Import Drum Track
Record Guitar Tracks
Record Bass Tracks
Record Audio Tracks
At this point I may have upwards of 20 or so tracks depending on how many vocal tracks I have
Export Bass Stereo Track
Export Guitar Stereo Track
Open Project1
Import Stereo Bass Track
Import Stereo Guitar Track
Dial in Superior Drummer presets and send to multi channel
Fine tune Superior Drummer and all SD busses to get the best drum sound I can
Export Stereo Drum Track
Open Project2
Replace dull drum track with new stereo drum track
mix all parts / automation / effect / etc
Export Stereo Mix
Create Project3
Import Final Stereo Mix
On Stereo Bus add compression/eq to taste
Export Final Stereo Mastered File
Seems to me I am wasting alot of energy? The issue I have is that SD eats up a TON of memory as does a lot of the plugins. I have starting at least using FX tracks and will send my "like" vocals all to one effects track. Same for Rythm guitars and Lead guitars. Like, I eq all the rythm guitars the same so they just get sent to 1 single effects track. BUT, If I was to try and do everything all in 1 project my cpu cant keep up.
i am wondering if there are easier ways to do this like...
Could I??
Bounce to a single Stereo Track
(Hide Orginal Tracks but not LOOSE edits) but Cubase shouldnt process these file during playback)
Track new parts or do mixing or whatever and then restore original tracks to maybe make more edits. So on and so forth. OR, Do you just have a better faster way?
Current Workflow
Create New Project1
Create New Project2
Import Drum Track
Record Bass Tracks
Record Audio Tracks
Open Project1
Open Project2
Export Stereo Mix
Create Project3
Could I??
