tjena
det gar nog bast att skriva pa engelska--
great song! try filtering the midrange in all guitar tracks at a higher frequency (sweep from 200Hz though 1kHz to evaluate what the appropriate attenuation and filter curve may be) as it will allow the low end drum sound to cut through the mix more... even the lead guitar tracks could use a significant cut--if you solo those tracks and bring the filter up progressively you'll see that nothing in useful harmonic content is lost while the kick and the body of the snare (upon disengaging the guitar solo) are more present.
in the future isolating the drum sounds would be a good idea, as it allows for far more control in frequency/amplitude. also, a narrow-Q high end boost in a discrete kick drum track helps in the transient attack's presence. snare too, though i generally focus more on a full and dark sound as opposed to a sharp and flat SMACK!
it seems as though some eq work would make your great track fucking killer--of course, that's simply my take on it...
om du vill kan lystna pa en av det sista skivor jag jobbade pa...edited, sequenced, mixed, manipulated...forlat, jag kan inte sa mycket svenska...det kallas lurker of chalice och har slappts ut pa total holocaust records i sverige. killen spelade allt in i en tascam mk4 igenom en guitar pod och roland vdrums. jag tog alla cassette och spelade dom in till min dator igenom ett motu2408. efterat var alting gort i
nuendo2, utom nar skivan var mastered...
