C
chris857
Hi guys. I use Sonar 3 Producer Edition and a Digi MBox as my audio interface. The MBox as two line outputs in the back, but when I go to choose an output for an audio track is only lists one output. I can record multiple inputs at the same time, but I would like to know how to create two output mixes. For example, one mix for the studio monitors and one mix for the singer's headphones. How can this be done? Why is the audio track in Sonar only showing output for line 1 as and output device and not for line 2? It works in Pro Tools LE but I like Sonar much better. Any help would be greatly appreciated! Thanks a lot. Also, the Mbox uses a ASIO driver. I don't know if that could be a cause of the problem, but just in case.
-Chris
-Chris
