A
awx
Hi Guys i recently bought a pair of KRK SYstem Rockit 5 active monitor speakers and i am experiencing some high pitch static coming through the speakers when the cpu is underload or burning a cd. It even just play music with nothing else running in the back ground just when the intensity of sound picks up. This has never happened before with my crappy stereo speakers. The static is also not there when im playing nothing and the cpu is under load
I have also recently installed 2 sata harddrives which have been installed in removable racks.
This seems only to happen with audio playback thru winamp or wmp and also with video playback. I recently had some problems with the same static happening when using guitar rig. I messed around with latency and still did not fix the problem.
My setup is as follows.
Delta 1010lt to Behringer MX1604a to Krk Rokit 5 speaker via jack cable.
If anyone could shead some light on how to fix this problem it would be greatly appreciated because it is starting to drive me nuts.
Thanks in advance
awx
Thanks in advance
awx
