B
Biempi
Okay, I know very little about how I am supposed to set these up, but I believe I did it correctly, and the sound is a bit distorted and crackly. It is very odd, and I would like some help with how to fix it. Here's what I've done to set them up:
I HAVE Bx5 D2 monitors
I connected the monitors to my Scarlett2i2 interface using two Planet Waves speaker cables.
I connected the power supply from each monitor into a surge protector that I have on the ground.
I lowered the volume of each monitor to minimal, and then turned them on.
I tried playing a song, and it was a bit crackly.
I went into audio device settings in control panel.
I double clicked on Scarlett212 for line out and went to advanced settings
I messed around with the default format and found that it would only let me test a few of the options, and the best sounding of the few that it let me test was 2 channel 16 bit 96000 hz.
I tried playing a song after that, and the problem wasn't as bad, but I could still hear crackling.
At this point I am stuck, and could really use some advice. Thanks a lot guys!
