WinstonCowboy
Whenever I turn the power off (on the Duo) and then back on...XP reinstalls the USB support...so if I go to the audio properties in control panel...and click to a see list of available soundcards...it shows:
USB Audiosport Duo
USB Audiosport Duo (2)
I uninstall the second one, but every time I switch off the unit...when I turn it back on XP reinstalls it again?!
Also, once the Duo is switched on...it automatically takes over as the default soundcard and the speaker icon(volume control) from my taskbar disappears. I can go into the control panel and open the volume window (for the Duo) and keep it minimized incase I want to open it real quick to adjust the volume...but is there a way I can get it to appear as the speaker icon on the taskbar? The way it does with my internal soundcard when the Duo is turned off?
WINSTON
USB Audiosport Duo
WINSTON
