cordura21
Hello, guys. In page 34 of "Getting Started with Digi 001", it says that to connect the Digi to a home stereo you should use the monitor output.
This output is balanced, while most home stereos are unbalanced. It also says to use a 1/4" cable, and to use a special adaptor for to convert to the common RCA inputs on the stereo.
The instructions doesn't say if you should use a TRS connector or a TS connector, it just says a 1/4" cable. I am currently using an RCA cable with two 1/4" TS (mono) adapters on the output of the Digi. Is this dangerous, could it cause a short in the output? What's the proper way of connecting them? even using individual cables for left and right, there's still the doubt between TRS and TS.
Can you help me? Thanks in advance, Andrés
