There are templates and there are
templates, just as there is mixing and there is
mixing.
Yes, I start my projects out with a generic template, but the purpose of that template is nothing more than setting up the DAW to get ready to mix, but with absolutely no plugs active, no settings assumed. I'll start with 20 tracks activated and locked, with track faders and track trim levels set to unity gain, and gain automation activated in each one and set flat to -3dBFS, just so I don't have to go through the process of setting all that up before I mix every time I start a new song.
But the idea of setting levels, EQ, compression, panning, etc. in a template for "consistency" across tracks - while it apparently may work OK for some people - for me just doesn't make sense, for a few reasons:
First off, as ido alluded to, consistency in mix settings assumes consistency in tracking. And consistency in tracking relies greatly upon consistency in *performance*. Whether one is self-recording or recording someone else, how many drummers have you come across that play song A with the same energy/pressure as song C? How many electric guitarists manage to turn their knobs back to the exact same position at the beginning of song B as they did at the beginning of song A? How many vocalists hold the same energy/emotion consistant through several songs? And so forth.
Even more so, how many *WANT* to? Just because it's one band, one album, one music style doesn't mean that everybody really wants to hold the same tone and levels and energy and so forth for every song - let alone within different parts of a singe song. And to assume otherwise when mixing just doesn't make sense to me.
Which leads to the whole point of mixing, IMHO; that is *LISTENING* to what the mix wants and taking inspiration and direction on what to do to the mix from the song/mix itself. "Templates" completely ignore that main, basic function of mixing.
But you can start from that template point and change as needed, right? I really don't want to get into this with miro again (
), but IMHO "SOP starting points" are not only useless, but counterproductive. They are nothing more than fancy versions of "presets". By starting making no assumptions as an SOP starting point, one is no further away from the final ideal then they are by picking what is ultimately an arbitrary assumption of a starting point; i.e. in that regard one is no better than the other. But by starting with assumptions as to how it probably "should be", one is biasing themselves and often inadvertently coloring what they are hearing from the mix, making such assumptions or SOPs IMHO inferior starting points to starting with a blank slate.
Mixing is a collaboration between the material and the engineer. Even the best engineer cannot take a mix where it does not want to go. But the best engineers do *MIX* the individual tracks together to bring out the best components of what the mix has to offer. This means plenty of automation (amongst other things), It means riding those faders like a jockey rides a horse.
It DOES NOT mean just compressing every track and laying those flat tracks on top of each other at relative gain levels that sound "about right", and then trying to correct the problems that creates by attacking the bad mix during mastering with Blowzone and MBCs and so forth.
This is the biggest problem I see with the OPs proposition, based upon what the mail order shyster of a "mixer" he was dealing with. I get the strong impression that there's no actual mixing going on there; that they are just for the first track laying the tracks on top of each other like lasagna noodles, and then doing even worse for the rest of the tracks by just copying those settings even though the rest of the songs are different.
That's not even mixing.
G.
