cool edit rec out of synch with playback
  • Thread starter Thread starter trdn1
T
trdn1
as the subject says, the recording that i make with just a simple computer mic, ends up being out of synch with the test drum loop at around 17 seconds. its like the playback and recording are going at two different speeds. To test it, i played back a drum loop, recorded the drum loop through the air (miked a pc speaker) then pasted the recording on top of the original. sure enough, at 17 seconds i could notice some separation, and by 30 seconds, it was a mess. please respond if you have any info...we're in the middle of recording and need to find a fix, quick!
yo, I had this same problem for a while... first, try messing withyour buffer settings... but WRITE DOWN WHAT THEY WERE ORIGINALLY. and what soundcard do you have??
xoxo
