I
imecho40
Only on the processor.If you spread a layer on both the processor and the heat sink,you essentially apply so much compound that it becomes an insulator,instead of a heat dissipator.You want a very thin layer that has full coverage on the surface.Since AMD chips dont have the same thermal protection that an Intel chip does,this becomes extremely important.I saw a fried AMD chip that had a very small spot that wasn't covered in compound,and it fried within seconds.You dont want enough on the surface that it squishes out when the heat sink and fan is applied either.
As far as OC (overclocking)goes,it is just a manipulation that allows the cpu to operate at speeds above its stated rating. AMD's are widely regarded as the best choice of CPU's for OC guys.Keep in mind that this will void the warranty on the cpu.Hope this helps..
