About 2 months ago they finished building our new house and we moved in…..it’s a 2-story….upstairs is my daughters room, an extra bedroom, a bathroom, and a walk-in attic area over the garage….I plan on converting this attic area into a personal music studio…..I’m mainly interested in soundproofing it….since I’m on a very limited budget for this project, I can’t afford to get too far into the acoustic treatment aspect….there is a door that goes into this attic area, and I plan to seal the room off and put another door going into the studio….the north wall has a window and the walls are brick exterior with 1” standard “waferboard” on the interior side (obviously with 2”X6” studs in the wall….the east wall has the studs for a knee-wall about 44” high, the west wall slants all the way from the top down to the floor, but I plan to knee-wall it about 2’ high, and the south wall borders the extra bedroom wall/closet. The ceiling is squared off at 8’ tall….the flooring is 1¼” thick tongue-and-groove plywood over 2”X12” joists….
Here are a few pictures to illustrate:
Under the floor I plan on spraying insulation about 6” deep underneath all of it….for the east and west sides knee-wall I plan to double wall them….on the north side I will spray insulation into the wall, and the south wall will get either a double or single wall (since there is already a wall with batts there)…..the ceiling slopes will get batting also.
Questions:
Questions:
- For the knee-walls, what would be a good material for the actual wall? Plywood? Waferboard? I noticed at Lowe’s they have foam walls in 4’X8’ sheets….these any good? I plan to spray insulation between the 2 walls that comprise the double-wall. Going from inside the room to out, does it need to be WALL/INSULATION/WALL/INSULATION/WALL or WALL/INSULATION/WALL/WALL/INSULATION/WALL? Do I stagger the studs? Is wood or metal the best stud to use?
- Do I need to double-wall the north wall? It faces the street.
- I would think that a 6” batting up the sloping slides (part of the ceiling) would be enough there…..any reason to double-up on that?
- Any tips for the door leading into the studio?
- Since I’m primarily concerned with soundproofing, I was going to put regular sheet-rock on the final interior walls/ceiling……
- I’m not sure if I will need to put another subfloor on top of the existing one…..the garage door opener may be a noise problem since this room is directly over the garage….if I need to put another floor down, do I need any rubber between the existing floor top and the new subfloor? For that matter, will rubber be beneficial anywhere in this setup?
- I plan to put a light in the middle of the room and a track light on either side of it. I want to put 3-4 outlets on the east wall and 4-5 on the west wall….would it be helpful to put the lights on a separate breaker circuit from the plugs?
- The HVAC comes in at the top of the south wall….I don’t know if it would be better to leave it flush with the south wall blowing across the top of the room or to have it come to the center of the room and blow down….any suggestions?
[/list=1]
Any help would be greatly appreciated…….thanks!!!!
