convering midi to audio s3
  • Thread starter Thread starter lopie
L
lopie
muting all track except cyclone (or vsts) and its paired audio track and then going to edit bounce track doesn't make an audio track -it say there is no audio to bounce
help
lopie,
how do you record to a computer sound card where is the wave file located after recording from the sound module out to the line in of the sound card? :cool:
lopie, did you select the track's contents before trying to bounce it?
desflurane... huh???
i recored cyclone midi track alone
then i selected the track (made it black) and highligted the track and did bounce to track but it said i have no audio to bounce- the sonar instruction say this is what you do - the sounds will export in the mix but i want to edit the audio track made by cyclone
There is no audio to bounce in a MIDI track.
Read the manual or the help system, it's all in there.
You could be missing the obvious here.
Select BOTH tracks.
Example: Select the track your midi is on(so it turns black as you say).
Hold the 'CTRL' key down and select your Cyclone output track.
So now you have both tracks selected.
Now try it,it should work if you've set it up right.
Post back and let us know. :)
well when i sent the cyclone out to "master" out
it did record the audio - i guess you just have to send it that way- thank for the help and encouragment
