frederic
More pictures. The last picture shows the entire table, bolted together, upside down. Tomorrow I have to do the cross pieces that actually support the gear, then grind down all the beads, prime and paint. Then dismantle it, and hump it up a flight of stairs without destroying my new walls
I gave up trying to have the table be one span, supported only on the far away sides, so I solved two problems with one solution... I made a leg support in the center towards the back of the table, so there is still room for my legs when I'm sitting in front of the table. Also, this gives me two additional bolt-through points to join the two sides of the table together, for a total of four. The leg will support the two halves, and also make the center joint that much more rigid. $22 worth of steel, all done.
Michael - welding doesn't have to be difficult. The process I use is Gasless Fluxcore MIG. The welder is a large box, with a spool of welding wire in it, which feeds through the hose and the gun (the part you weld with), and the wire forms the arc. All you need for this kind of welding is a 20A, 120V outlet, a face mask, gloves, and the welder itself. Mine is a Lincoln SP135 which is more than enough for welding 1/8" thick material. This unit is typically $550 - $600 or so, and a really nice unit. Hobart and Miller also make welders of this time, and cost a hair more.
If you're ever in my neck of the woods (central NJ) I'd be more than happy to teach you how to weld with this method. Within 2 hours you'll have it down pat. Its really that easy. Just takes a little time to figure out how to set the machine for different thicknesses, as well as learning the hand control. Also there will be wood on the front of this, giving me a nicer appearance since I'll be using poplar. Also, a desk surface so I can route an indentation for my trackball and keyboard, then cover with foam and stretched material over that, for a nice cushiony surface to lean on. More than likely I'll use vinyl, since its inexpensive, easy to clean, and provides a nice tough surface as long as one doesn't puncture it. The desk surface supports aren't attached yet, that should occur tomorrow if the weather holds out, snow wise.
Rick - I used to be vary happy with a ibanez guitar, a 4-track, and a roland TR202 drum machine. This was back in 1983 though... things have scaled over the years - scaled up!
