Before we can help you,  it would help if you actually went out and looked at materials that are available. Generally, if there is a Home Depot, Lowes, or those type of places there are many materials that they carry. Other than that, a lumber yard may have a variety or even a cabinet shop.
   To give you a few clues to designing the unit, think in terms of MODULES or sub assemblies. Such as:
  Rack mount boxes
  Main support frame(metal, solid wood or boxed beam
  Equipment Decks(panels or cheap solid door will work too)
  End Caps.
  Bridge support(personally I would use angle iron for the span)Bridge Deck
  Backs
  Legs, feet, or bases for the rackmount boxes.
And generally speaking, if you use sheet goods you will be using cabinet type joinery.  Here are a few tips.
   Cabinet work is only as good as your squareness of cuts. If you have no table saw, I would suggest laying all the parts out as a cutting bill and have a cabinet shop cut the parts.  This will assure proper fit and ease of assembly. Remember, one panel out of square will make not only assembly difficult, but will affect openings, levelness, connections etc.
   Panel or sheet goods require not only squareness of the panel, but perfect 90 degree cuts perpendicular to the  face.  Rabit joints facilitate assembly. Pre-drilling pilot holes and countersinking for screw heads also make for ease of assembly.  If you have access to a router and a few carbide cutters, this will help emencily, but its not impossible to build things without them.  If you don't have a router, maybe the cabinet shop can do the few rabits that will facilitate the assembly process.
 Rabits and dados allow for alignment of parts, although butt joints in panels can work too, but plan for shear(breakout in MDF).  I'll draw a few things to illustrate for you.  Buiscut assembly is good too, although takes a special tool and or a router with a spline cutter.  Even metal angle brackets will work too.
There are a million ways to join things together, but KISS strategies work best.    KISS= Keep it simple stupid!!
(not callin you stupid-its a standard design philosophy, although I tend to ignor it for my stuff.
   Do NOT nail anything.  Use screws and hardware to fasten things together. I generally stock "grabbers" which are like drywall screws. You can buy them in bulk at most hardware stores. Generally, you will need 4 lengths. 1", 1 1/4",
1 5/8" and 2" , but for fastening bulkyer things its handy to have 2 1/2" and 3" on hand.  They usually sell for about $3 lb.  Also, a good quality glue such as Tightbond should be used.
   As far as materials,  there are a few that are normally used.  MDF, or Medium Density Fiberboard is the most used material as it is strong but heavy,
but because it is absolutely flat, it is the material of choice now days for general cabinetry and fixture work.  Then there is Melamine, which is MDF with a fused layer of a thin laminate which is durable, water resistant, scratch resistant, and is easy to cut and machine joints.  Melamine comes in various finishes such as woodgrains, white, black and sometimes grey.  But usually is stocked at HomeDepot type places in white and woodgrain.  Also comes in 1/4", 1/2" and 3/4".  Sometimes you can find it with a real hardwood veneer if you are lucky.  Such as Oak, cherry, Ash, or others, but is generally more expensive.  One of the plus's of MDF is its paintablity. Thats what it was designed for.  But a good grade of primer is required before a finish coat is applied.  Even exposed edges paint well if primed,  Some places will even POWDER COAT it for you  but it's damed expensive. Paint is just as good. Even latex, although I always spray lacquer on MDF.  Veneers will require a finish coat as well, and exposed edges usually will have to be edgebanded with a layer of solid wood or taped with rolled solid wood edgebanding. This comes in small rolls with a pre applied hot glue which you, cut to length and then IRON on the edges with a regular household iron. But since it is 1/16" wider than the thickness of a panel, you then have to either file the edges, or cut them with a utility knife, or use a special beveled trimmer that cuts both edges off at once. It's about $10, but worth every penny.
   Generaly, I use black melamine for my projects with a black melamine edgebanding or Black laminate edgebanding.   One aspect of using MDF, is screwing into the edge can split the panel. Therefore, not only must you drill an oversize hole through the panel you are fastening, you also must drill an UNDERSIZE hole in the edge for the screwthreads to grab with out spliting the panel. I usually use a special TAPERED drillbit with countersink built in. Works great. Plus it does everything at once. You must clamp the panels together to keep everything aligned.  And thats another animal.  CLAMPS.  Never enough in a shop.
  Then you have plywoods.  Although ply is good, unless you purchase a cabinet grade ply, it will have VOIDS on the inner layers. And it will REFUSE to lay flat, untill adjacent perpendicular panels are fastened to keep it straight.
 There is the standard old AB grade Fir ply, but I personally would  NOT use it.
If anything, use cabinet grade BIRCH PLY. Paints well, machines good, cuts clean, and drills smoothly and is relatively cheap  The best cabinet ply is called Armorcore, which has two layers of 1/8" thick MDF, and is right below the veneer surface. This keeps it absolutely flat, and keeps the veneer flat as well. Other grades veneer is applied to a layer of fir which allows the grain of the fir to telescope through the veneer.  All the other aspects of MDF are applied to ply also. Comes in veneers, or even a layer of MDF on the surface.
 Doesn't paint smoothly though.  Veneers require a clear finish.
   And speaking of finishes.  Laminates are great, but require tools and experience to apply. Expensive too.  Paint, varnish, Ureathanes, and other types of finishes usually come out better on MDF.  And then there is speaker box carpet or indor outdoor carpet too.  AND, there is a CHEAP automotive carpet that is sold at most carpet places. Looks good and applys easy with spray on or roll on adhesive and staples. Comes in black and grey. Even Home
Depot type places carry some kind of cheap carpet.
  Well, I'm out of time and breath
  Hope this helps. If you need some drawings to explain assembly, cutting, and joinery tips, just holla and I'd be glad to help.
fitZ
