P
petie_gwm
Whether recording from adobe audition or windows sound recorder as a wav, the recording levels are not consistent. I record lots of things that have quiet moments, ie classical, spoken word. Whenever the audio in the original recording is quiet, the recording almost drops out entirely or becomes very low. When the music picks up steam, it takes a second for the recording to come up to full volume. Basically the levels are all over the place. If it's a pop or rock or dance song with even levels that I am recording I don't have a problem. Any suggestions on not having what seems to be an automatic recording level adjustor would be appreciated.
I am using XP
C-Media AC97 Sound Device
If this is my sound card doing this automatic adjusting I have researched and found the following:
In my programs under "start" I have C-Media 3D Audio. Subcategories there are only "Play 3D Demo program", and "Uninstall C-Media 3D Audio".
The only configuring I seem to be able to find is the basic windows volume control panel. However I see a blue icon in the task bar on the c-media website. However, I don't have that icon in my task bar which has been confusing me. I just went to msconfig in "run" to see if it's unchecked in my start-up items but it's not even listed there. I cannot find any way to get to any options on my sound card at all. All I can get to is the standard Windows Volume Control window. Any suggestions?
Thanks
I am using XP
Thanks
) - it is an .exe file so just run it and it will install the drivers for you. You should go through the instruction manual yourself, but basically you'll just be selecting ASIO drivers in whatever audio program you're using. As well, there is an ASIO panel that you use to control basic features like latency, etc.
