a wee bit more help needed. . .
okay, . .need a little assistance, please sirs, . . I connected this all up last night, and it worked great!!!! I got some fantastic drum sounds using just 2 drum mics, recording the entire drum kit in mono (a MXL-v67G, as a single overhead -- roughly 2 feet above, and slightly behind the drum set -- and an ATM25-Pro on the kick)
I was very impressed with what I got, . .the LDC added some nice overall fullness to the kit, while the ATM 25Pro, added some good bottom-- Eventually, I would like to try this setup, using an SM-57 as an overhead, and the 25Pro in the kick-- I hear that a few guys on the Tascam forum, I think 'REEL, and maybe 'FM' use this as an overhead, and get some excellent results with this mic.
A Reel Person said:
Assuming you're using a home-type CD player, and not a portable,...
AND assuming you want to record the CD tracks and LIVE tracks simultaneously,...
1) Find two RCA-to-1/4" adapter plugs,... a simple, low-cost item.
2) Connect a simple RCA/RCA-stereo cable to the CD player's outputs.
3) Connect the two RCA-to-1/4" adapter plugs to the ends of the normal RCA stereo cable.
4) Plug the 1/4" plugs into CHANNELS 1 & 2 of the 424mkII.
5) Set TRACKS 1 & 2 to DIRECT recording mode.
6) Adjust TRIM and faders on CHANNELS 1 & 2, per normal setting procedures. [See manual].
7) Plug your instrument and/or mics into CHANNELS 3 & 4, depending on whether you're just using guitar, 2-mics for drums, or a stereo submix of drums from another mixer.
8) Set TRACKS 3 & 4 to DIRECT recording mode.
9) Adjust TRIM and faders on CHANNELS 3 & 4, per normal setting procedures. [See manual].
10) Press PLAY on the CD player and RECORD on the 424mkII, and go to it!
Anyway, a few things that I'm a little sketchy on:
ONE:
When you plug the cd player into Ch 1 & 2 using 1/4" plugs-- is it best to control the signal volume from the incoming cd by the TRIM, or CHANNEL FADER? What is a good rough rule of thumb? *** TRIM (low), and FADER (high) ***
(it seemed that the TRIM had less control over the input volume--then the CH FADER)
TWO: (Pan)
with the cd in CH 1 & 2, and the drums on 3 & 4, what is a good idea,to have the PAN knobs on ( I realize that this question is relative, but, a good reference to start-- would help)
THREE: (Hot Peaks)
I was getting a lot of spiking HIGH PEAKS when recording with the cd, and drums-- But, on playback,..there was hardly any distortion, if any. . . Is it possible to overload the 424mkII, and damage it, by recording too hoot?
FOUR: (Headphone mix)
I have a Headphone amp. But, since it was only me, and a cd-- I used the headphone jack on the 424 to track with. . .But, I was really struggling TRYING to get a good Headphone mix-- using the the headphone LEVEL knob-- Is it best to keep it up high, or mid, . .
FOUR: (Monitor Switches)
Struggling here, . .what's a good reference position for these switches during tracking with the cd, . .and should the positions change during playback, or mixing?
FIVE: (EFFECT 1, & EFFECT 2/TAPE CUE KNOBS)
Okay, . .REALLY struggling with these knobs, . .Briefly,..please explain to me, what is the BASIC function of these knobs are, and what position they should be in, during tracking and recording.
Thanks again for the initial help, . . it sounded awesome for the first time!
