conecting midi
  • Thread starter Thread starter LukeCakewalker
L
LukeCakewalker
hello I have cakewalk home studios 2004 on my pent 4 commputer
with audio philes sound card and sythensizer connected how do i get my
midi tracks to record can only here sound on audio trackes with the sythensizer.can some help me? what did i do wrong ?
thank you :cool:
Well, what synthesizer? And how do you connect it? To record MIDI, you can either record them using MIDI keyboard connected to your PC via MIDI, or "draw" the notes in Piano Roll View / Staff View.
Jaymz
Thank you for your response.
I've been conecting with both midi cables an audio cables to my
systhensizer..which is a emu mk-6.
what am i doing wrong bro?
thank you
Your question is kind of confused. You can't "hear" MIDI tracks. MIDI is a description of the parameters of a performance and needs to be interpreted by something, either a soft-synth or hardware synth. So, if you're trying to "listen" to the MIDI tracks themselves, then no, you won't hear anything. If you're saying that you have the output of the MIDI track routed to the E-Mu and you can't hear IT, then there's a problem.
I'm not familiar with Cakewalk HS, but I use SONAR. Have you enabled the Audiophile's MIDI interface in HS? I haven't used this program, but somewhere, you will need to tell the program what MIDI interface you are using. Look for a "Preferences" or "MIDI" tab somewhere in the Menu bar.
Try a simple experiment. Load a project that has MIDI files in it. First see if the MIDI tracks play back through the computer. It should, if you load it properly, load and playback through software. If that works, try changing one of the MIDI tracks output to the Audiophile.
Of course, another obvious question is do you have the MIDI "OUT" of the Audiophile connected to the MIDI "IN" on the E-Mu and vice versa?
These are generic suggestions. Unless you give much more specific information as to what's happening and exactly what you've tried to fix it, there's little more that we can tell you.
Ted
