Yo Mikeeb! First, I have no problem with DMP-3 as a starter pre. Aside from AT4040/4050, and Rode K2- all of which are perfectly good mics, there are many others worth considering. I like Shure KSM44 and AKG C414, but both are at the end of your budget, even used. A couple of dark horse mics that no one has mentioned are B.L.U.E. Bluebird and AKG C2000B. C2000B is discontinued, but is an underated multi-purpose small diaphragm condenser in a larger housing than a pencil mic, so it's pretty good on vocals. The Bluebird is a large diaphragm condenser, excellent on
acoustic guitar and some vocals. They also made the baby bottle, which is in your pricerange, and is very good on some clean vocalists. I've actually had better luck with the Bluebird on vocals than the Baby Bottle. Here's your biggest problem- Vocal mics are like shoes. They either fit, or they don't-and the price is a very poor predictor of what will sound good on any given vocalist. Furthermore, for different material, the same vocalist may benefit from using different mics.
My best advice- find somebody on this board who lives near you and owns a bunch of mics. Maybe somebody will let you try out a few candidates. I'd do it for the price of a Chinese dinner, but I'm in Boston. Another thing- I question whether you need multipatterns, and NTK is a perfectly good cardioid that is a little cheaper than a K2. Best of luck in your search. Here's my best advice: As nobody can predict what mic will make somebody sound good, do the best you can to find the mic that makes *you* sound good. If you can't do that, buy respected mics from well known manufacturers that you find in the "B" rooms of serious studios. This does 2 things- First, it increases the likelihood that the mic will be good for recording *something*, even if it isn't what you intended. Secondly, it means that if the mic doesn't work out for you, it's easier to resell if for a fair price.-Richie
