How do you record live gigs? I used a splitter snake, fire wire mixer got all drums separate, guitars, bass keyboards and vocals plus a line for the main mix. What is your recommendation and style?
make sure that your not using a cheap splitter.
You need ISO balanced transformers at each channel or the FOH main mix or your recording is to experience some buzzing. the real good splitters have a ground lift on each channel too.
Plus never forget to turn all phantom power off at your end let the FOH or monitor world worry about that, two different phantom sources will lead to problems in the main mix or your recording.
