bouldersoundguy
RFR: The A&H unit is indeed interesting but using one is only a smidge away from going PC!
As you say, you need a mixer to drive one (or a bank of preamps) but I would urge caution, the mixer needs 16 "inserts" better Direct Outs to drive the box. Then, how would you mix the resultant? Send the tracks back to the mixer*? How? 16 more line inputs or a heck of a lot of plugging?
MUCH easier and better quality to mix in a DAW.
*I have done some "back of env'" drawings of a switching box that would allow a 16ch mixer with inserts to interface with the recorder. Don't of course have the hardware so I cannot develop it.
Dave, you would use an inline type studio mixer. In addition to the mic and line inputs each channel has direct out and tape in. The channel can route the main input to tape and monitor the tape return at the same time. Tracking, overdubbing and mixing are all accommodated nicely.
But it looks like it's really for live recording. Capture the show and dump it to computer later. For example, I use a Soundcraft GB2R and an Alesis HD24. The GB2R has direct outs. The ICE-16 could replace my HD24 without any change in cabling, but I would lose the ability to capture my live mix and a room mic along with my 16 direct tracks. On a mixer with no direct outputs it's a simple matter to tap signal from an unused insert or split the signal from an insert being used, which is what I did for years on the Mackie I used before I had the Soundcraft.
